Announcements
We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
XREFOVERRIDE feature request (selective properties)
Good morning all,
XREFOVERRIDE is a helpfully command but I suggest to add the possibility to active only for a selected properties (color, linetype, lineweight, ecc.).
Also it's better if is possible to select for each xref individaully.
I think is a good command but need more option and setting to be used successful.
Thank you.
rkmcswain
This is not a wishlist forum, and there is not one for AutoCAD here in the Autodesk Forums, so the development team will never see this. You might want to head over to the Augi wish list and add your thoughts there.
R.K. McSwain     | CADpanacea | on twitter
