xrefence list in AutoCAD 2020
CliffTurnerFuse
Message 1 of 11
CliffTurnerFuse
I am switching from AutoCAD 2018 to AutoCAD 2020.
I can't find anyway to get the Xreference List.
I see the suggest command is the EXTERNALREFERNCES, but nothing happens.
Help
Replies (10)
Message 2 of 11
tboehler
XREF
Message 3 of 11
jrsimmons4
If you have multiple monitors, sometimes the XREF panel appears on a different monitor than the one your AutoCAD program is on. Or it's tucked into a sidebar that is hidden until you hover over it.
Message 4 of 11
imadHabash
it may shifted away from your screen , I suggest to try  Alt+Space bar  then type M then by your keyboard arrows start to get your shifted box .
Imad Habash
Message 5 of 11
CliffTurnerFuse
Typing "xref" does nothing.
Any other idea ?
Thanks -KLYPH
Message 6 of 11
CliffTurnerFuse
I do have only one monitor.
How do I check  to see if it is under the Space Bar?
-KLYPH
Message 7 of 11
CliffTurnerFuse
I've tried the Alt-Space Bar, type "m" and played with the keyboard, with no results. I checked that I did not have the "NumLock" on.
I've also used the "EXTERNAL REFERENCES PALETTE", with no results.
Any other ideas?
-KLYPH
Message 9 of 11
Kent1Cooper
Does the XR alias for the CLASSICXREF command help?
Kent Cooper, AIA
Message 10 of 11
imadHabash
Would you please show us a screenshot for this - but nothing happens - moment ? also you may check if any updates needed from your Autodesk Desktop App .
Imad Habash
Message 11 of 11
Partenheimer
I've experienced instances where a "visible" palette is docked. ...but for some unexplained reason its only about a millimeter wide so you don't see it. In those situations, to "restore" my palette, I just need to stretch that edge until its visible again. Perhaps your issue is similar to that.
Michael Partenheimer
