Message 1 of 18
		09:39 AM
    - Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've used Microstation for the past 8 years and curious if I can change some settings in AutoCAD.
1. I can't get (Xref) referenced dwg line colors to update into my current drawing. I can change the color in the referenced dwg (in the layer manager) and save. Then go to my current dwg and reload the referenced file but the color change is not reflected. If I detach the file and re-attach the change finally is made, but I find this unnecessary.
2. When I reference a dwg it also references every dwg attached to the reference, all I want is the one dwg.
Is this just how AutoCAD is or can I change these?
Any Info would greatly help!
