XREF using NAMED VIEW
Llam.Tech
Message 1 of 9
Llam.Tech
Hi, I am working on a 3D peice. I would like to show 3-4 different views. But my client requirements needs all drawings and drawing boarder should be in Model Space. Since, I can not show all different views in just one model. I thought of creating a different file and create a NAMED VIEW (TOP view), (Front view) and (ISOMETRIC view) and do XREF's of those SAVED VIEWS. Unfortunately, my idea didn't work out.
Do you guys have different approach on this?
Jay
Accepted solutions (3)
Replies (8)
Message 2 of 9
You can show multiple views while in model space. VPORTS.
Thanks.
Message 3 of 9
Llam.Tech
Hello Chauhuh,
I need to put it inside a boarder for a formal deliverable.
Jay
Message 4 of 9
Ah I see. But that is why we have viewports and paperspace...lol.
The client requirement that it all be in paperspace sounds onerous and like the client doesn't realize how AutoCAD works.
You could do block snapshots of all the different views, set them up all pretty in model space, and then add your border. FLATSHOT is what the command is I think.
Thanks.
Message 5 of 9
Llam.Tech
Actually, that my last resort. Since, my client only needs a 2D drawings.
Maybe, Autodesk can create those type of command just like Bentley (MV8i) has.
Jay
Message 6 of 9
GrantsPirate
Flatshot is the way to go I think.  You could make a block of the model, copy it and rotate it as needed for the views also.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 7 of 9
jggerth
Have you tried the EXPORTLAYOUT command?
Message 8 of 9
Llam.Tech
Message 9 of 9
Llam.Tech
Oh, wow.. this is a cool command. I definitely need this command in the future. Thanks JGerth
