Xref problem when copying to other PC
I have drawings with several xrefs, when I copy them to another PC, drawings can not find their Xref path. How can I copy the file so that i do not need to reset the xref path?
Kent1Cooper
By setting up the same file paths and file locations in the destination computer as the files are in on the source computer?
Kent Cooper, AIA
pendean
Community Legend
Community Legend
Explore some tutorials on the topic in HELP and online: I'll get you started here
https://knowledge.autodesk.com/support/autocad/getting-started/caas/simplecontent/content/fix-broken...
HTH
DumR0
solution:  when you copy the the dwg file from one pc to other pc, copy also the files that was inserted with xref, in the same folder, then just enter command xref/ select all files and reload.
-didier-
Bonjour @Anonymous
If you use the command ETRANSMIT the zip file will contain all the xref in the same file
It is the most powerfull command to save worflows with XREF
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
