Xref Manager Dialog box missing Sidebar
GeeHaa
GeeHaa
Hi I'm using AutoCAD 2018 and the Sidebar on my Xref manager dialog box went missing. I tried going to the registry and looking for it to reset but I don't see it. Any help Would be much appreciated.
Valentin_CAD
@GeeHaa ,
Show us the entire panel.
Here are a few suggestions:
1. If shown on the right-side, anchor to left and then pull out.
2. Consider changing the Workspace.
3. Ribbon or toolbars are missing, blank, or disappear in AutoCAD Products
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
pendean
Community Legend
Community Legend
Is it not on the other side of that pop-up?
tboehler
could it just be the case as shown below?  no slide bar on first image because of no reference?
slide bar is on the second image - when a reference is attached.  more info to show.
GeeHaa
Thanks for your response. It had moved to the right side but I Couldn't see it because it was off screen and I couldn't move it because there was no place to grab it from. I shut down 2 of my monitors and it reset to where I could see it. From there I Anchored left. Thanks again you Solved it!
