Xref looks totally gray
dcnkzr
dcnkzr
Hi everyone I have attached 2 xrefs to my drawing one of thme seems totaly gray when I open it it seems correct but when I load it into my drawing it totaly looks gray
BhaskarMurari
Can you try this:
Command: XDWGFADECTL : Enter new value <50>: 0
Also check this:
Command: XREFOVERRIDE Enter new value <1>: 0
Dimmed content may be located on locked layers.
Command: LAYLOCKFADECTL Enter new value <50>: 0 ↵
imadHabash
@dcnkzr
Q: Is the xref a picture (image) or just normal inserted xref with lines and arcs...etc?
You may try:
  • Toggling on/off hardware acceleration from GRAPHICSCONFIG command.
  • Type Gfxdx12 = 0  then close and restart AutoCAD.If it makes no difference set Gfxdx12 back to 1.
Imad Habash
obulesub
Hey @dcnkzr,
Checking in if the workarounds suggested by BhaskarMurari and imadHabash helped you resolve your issue?
If it did, please consider marking their reply as the Accepted Solution so other community members can easily find the answer.
If the issue persists or you require any additional assistance, please feel free to reply with an update.
Thank you!
Obulesu | Community Manager
