Palatte issue
Palatte issue
wcthunder27
Palatte issue
wcthunder27
I'm trying to insert a a plan into paperspace from my palette. the inserting plan contains a grouping of blocks. when i try to insert using my palatte (already saved in palatte). it insert a grouping of distorted blocks on top of each other. i tried to group the blocks as one one block, still same effect. Could this be because of difference of versions. The plan I'm trying to update was created 2010. any suggestions would be appreciated.
imadHabash
@wcthunder27
Would you review the Explode setting in your palette for the plan block. Make sure that it's not selected.
Imad Habash
Kent1Cooper
@wcthunder27 wrote:
... it insert a grouping of distorted blocks on top of each other. ....
Any time things end up in different locations than expected, the first suspect is that running Object Snap is on.  Does it work right if you turn off running Osnap?
Kent Cooper, AIA
ChicagoLooper
@wcthunder27
<<.....I'm trying to insert a a plan into paperspace from my palette....>>
What does insert a plan into paperspace mean?
Do you mean you're trying to create a new layout tab which has objects already on it such as titleblock and various blocks? Please explain. Uploading screenshots would be helpful.
Chicagolooper
BhaskarMurari
Purge Old Block Definitions
Before inserting the updated blocks from the Tool Palette, remove any existing block definitions with the same name from the target drawing.
  • Run the PURGE command.
  • Select Blocks.
  • Click Purge All.
Clean the Source Drawing Using WBLOCK
  • Open the source drawing containing the furniture plan.
  • Run the WBLOCK command.
  • Select Entire Drawing.
obulesub
Hey @wcthunder27,
Just checking in to see if any of the workarounds suggested by the community members in this thread helped resolve your question.
If so, please consider marking the reply that helped as the Accepted Solution so other community members can easily find the answer.
If the issue persists or you need any further assistance, feel free to reply with an update.
Thank you!
Obulesu | Community Manager
