XREF Layers
XREF Layers
XREF Layers
I am having issues at the moment with xref files in my current project. When loaded in, all layers are greyed/faded and not visible in the model space. The red circle denotes area where xref should be showing up. I'v tried entering XDWGFADECTL and setting to 0 in both the current drawing and the xref drawing but nothing is happening.
Any help would be greatly appreciated. Please see attached image.
Ryan
pendean
Community Legend
Community Legend
Your screenshot is listing UNRECONCILED LAYERS: why not resolve that problem first in your top file, then click on the ALL option in that LAYER command pop-up Filters section and see what is actually going on with your XREF layers.
Here is a tutorial about the topic http://cadablog.blogspot.com/2015/01/dont-ignore-unreconciled-layers-they.html
Thanks for the response, I'v tried this and still not working. I even reconciled all the layers and still no result.
imadHabash
if do you mean in the Layer Proprieties Manager then this is Normal ... this is the way how attached xref layers will appear .
if you start a new empty CAD drawing and attached that xref ... does it appear or what ? if yes .. then get back and check your layer status .
Imad Habash
ian.mag
Hey @Anonymous
You can adjust the display of of your xref as follows:
  1. Go to options (either by using the right click shortcut menu or the the application menu)
  2. Display tab (bottom right corner)
  3. The scale ranges -90 to 90; -90 less faded and 90 very faded
RobDraw
There are a number of reasons for this to be happening. Post the drawing and the XREF to illuminate all doubt and guessing.
Rob
