XREF layer change color with NO override
all are in the model space: One of the layer in XREF is white, but in current layer is red. I have checked the layer, which has been set to white. However, the red layer won't change. I couldn't figure out the reason and a method to let the layer display white (for plotting purpose)
imadHabash
>> One of the layer in XREF is white, but in current layer is red. <<
would you show us your case please ? xref layers usually have a long unique layer name when attached so i suspect on how you use it as current.
Imad Habash
RobDraw
The problem may be in the XREF file. Make sure the color of the objects in question is set to bylayer.
Rob
