xref bind function grey out
Message 1 of 8
I right click the xref but the bind option is grey out. Any ideas to bind the xref? Thanks
Replies (7)
Message 2 of 8
rkmcswain
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 8
john.vellek
HI @Anonymous,
What kind of file is being xreferenced or attached?  If the format is an image or PDF, then you will not be able to bind the information.
John Vellek
Message 4 of 8
john.vellek
Hi @Anonymous,
I am checking back to see if my post or @rkmcswain's helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 5 of 8
marc.khalil
I have same problem. The linked file is CAD. I can detach it, but I can't bind it.
Message 6 of 8
pendean
Community Legend
Community Legend
Message 7 of 8
jasonmin77
Observer
Observer
Hello John,
I'm sure you are trying to help but most of people would know if they are refing pdf or image. Try to be mote diligent when answering someone else's questions. It's cad I am sure. Let's not just answer from your perspective view immediately.
Message 8 of 8
RFrenetteREPZ2
I had the same issue. It was caused by the Xref being modified, and I was able to bind after reloading the XRef.
