Xref advise
Xref advise
Xref advise
I am trying to delete some files in the Xref but it wont let me detach them.
Any advice?
Hi Oscardo
Are you trying to remove the files from your drawing and are they nested within your xref? If so then you'll need to open your xref and remove them from there.
Can you provide a screenshot of your xref pallet?
imadHabash
try to twist between Tree view and List view as attached image, any xref listed under the main xref which have a (-) symbol,these ones if you did not need them to appear in your drawings which attached in you can change their status to Overlay.
Imad Habash
Hi Oscardo,
Have you found a solution to this issue?
