X-ref Scaling Inconsistency
Jake_PCH
Jake_PCH
Dear All,
All 3 X-ref files (A, B & C) & host file (D) have their units set to millimeters for both source & target.
However, when I reference files A, B & C into D, file A is referencing in at a scale factor of 1000x smaller. I have circled the locations of each x-ref file within the host file to assist navigating.
I cannot figure out why this is happening - can anyone provide an explanation and solution?
Kind regards,
Jake
pendean
Community Legend
Community Legend
FILE A's units are set to meters
AKA 1000 times.
HTH
Jake_PCH
Sorted, thank you Pendean.
How does this unit setting differ to the (source & target) insertion scale settings within User Preferences?
marianne.mcdonaldTZVTF
the "dwgunits" inside your xref file are set to metres. So when Autocad is attaching the xref, it detects those units and multiplies by 1000 without asking you. Presumably this overrides the source & target units that you set in the xref settings.
(It's especially fun when the xref is set to "unitless")
