Workspace keeps resizing itself
Normally there is no space between status bar and command line, but the software is producing space between these two elements of the interface and it can't decide which it wants, space or no space, so its resizing the whole model space viewing area, sometimes every few seconds whether window is maximized or not. This is so distracting visually and it just makes it hard to aim and click on something. Does anyone have any idea what this is?space between status bar and command linespace between status bar and command line
no space between status bar and command lineno space between status bar and command line
pendean
Community Legend
Community Legend
Johanna_Esteban
H @Anonymous ,
You're right, it's annoying.
It happens to me in the 2020 version with a 4K monitor, what I have done is reduce the width of the AutoCAD window to cancel that behavior, however, that failure was reported to the AutoCAD team at the time, it is possible for the future version is corrected.
Kind regards,
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! 😉
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
vinodkl
Hi @Anonymous
Type in the command "STATUSBARAUTOWRAP" and set it to "0". That will fix the issue🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
B.Morton
This did not work for me
pendean
Community Legend
Community Legend
Perhaps you have something else going on: can you detail what the issue you see is, what your exact AutoCAD details are as shown in your ABOUT command, and your OS please.
And let everyone here know what exactly you tried.
