won't plot color from copy paste
 i copied a few things from excel to autocad with color red and black but when i print it to pdf it only shows in black and the red part disappears. in preview show the prefect how it should be. I also drew a red square in autocad and it shows the square anyone have an idea what the problem is? i have attach the file you kan see it in B0 horizontaal in paper space
Accepted solutions (3)
Valentin_CAD
@Anonymous ,
Change the OLE Plot Quality to Color:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
user181
I agree with above comment from @Valentin_CAD  change ole object plot quality to something that prints color and for the red square select the hatch and on the properties palette choose select color and change the color to a true color. True colors always print in color.
imadHabash
Your issue will resolved if you change the plot quality as shown below .. select ole object then press Ctrl+1 .
Imad Habash
thank you all for replying
very much appreciated
