wireless keyboard lags wired keyboard works
nlezotte54
Message 1 of 15
nlezotte54
wireless keyboard lags sometimes freezes AutoCAD Archtecture 2021
wired keyboard works no issues
wireless mouse works no issues
Replies (14)
Message 2 of 15
ennujozlagam
try DYNMODE set to 0 and see if helps. thanks
Message 3 of 15
Alfred.NESWADBA
AutoCAD does not have a direct control or interface to the keyboard, it gets the input from the operating system.
If 2 keyboards work different then this depends on keyboard drivers but not AutoCAD handling them.
If you have a combination of mouse + keyboard as set (one connection to USB to your workstation), this could also be an issue, that there exists a conflict.
A general rule I have when keyboard input is lagging in AutoCAD then I suggest to dock the command-line and not have the one-line version on the bottom of the screen.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 15
Tomislav.Golubovic
Just use wired then. At least you know it works
Message 5 of 15
pendean
Community Legend
Community Legend
Does your wireless keyboard need recharging or new batteries?
Or you need an all new different make/model wireless keyboard, drivers?
Message 6 of 15
nlezotte54
Didn't work
Message 7 of 15
nlezotte54
Always have used a wireless keyboard and mouse without issue. This started
with version 2020 and 2021. keyboard works fine with other applications
(Microsoft Office etc.)
Message 8 of 15
nlezotte54
Nope. Tried new batteries, different wireless keyboards, Dyamode set to
zero. I only have an issue in autocad. Started with version 2020 and 2021.
Works fine with Microsoft Office etc.
Message 9 of 15
Alfred.NESWADBA
And with wireless(!) ... as keyboard with cable seems ok.
Again, I'm quite sure that the driver or keyboard type is where you need to investigate.
- alfred -
Alfred NESWADBA
Message 10 of 15
pendean
Community Legend
Community Legend
Which brand/make/model? I use generic brands for both wireless keyboards and mouse(s), no issues at all with 2020/2021 in Win10Pro on a desktop at the office nor n a docked laptop at home.
Message 11 of 15
nlezotte54
Logitech MK540. Have had this keyboard for years. Just last 2 versions of
autocad had problems
Message 12 of 15
scottspeig
Did this ever get resolved?
I've noticed that on occasion, my Logikal K270 stops working within AutoCAD (LT 2023), but works in every other program open on the machine. Presumably it has to do with AutoCAD waiting for a command (as it is after I start a process such as copy) which interferes with the computer accepting the input from the keyboard.
As to "check with driver" response, as it is ONLY AutoCAD that has the problem, it is highly unlikely that the supplier of said driver will accept it being their issue...
If this hasn't been resolved, I'll have to revert back to the wired keyboard, but seems odd that there is even a conflict really...
Message 13 of 15
nlezotte54
Never got resolved
Message 14 of 15
nrz13
I never used AutoCAD 2021, but I never had issues with AutoCAD 2020 (or any other version I used) using a wireless Logitech keyboard (K750).  For a while I had issues with my Logitech mouse (MX610), but that was because the dongle needs to have direct line-of-sight to work well (I added a USB cable extension to the dongle and haven't had issues since).
I'm using the SetPoint software and driver.  I've read Logitech's newer software has a lot of issues, but haven't tried it myself.  I'm currently using SetPoint 6.67.83 with driver 5.90.41.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 15 of 15
pendean
Community Legend
Community Legend
