Wipe Out Frame still visible after changing variable
Hi All,
I'm using the WIPEOUT command in Paper Space - ACAD 2017.  I am trying to change the FRAME variable from 3 to 2 and have it permanently stay 2.  Bottom line - I do not want to see the WIPEOUT frame.  When I close the drawing and reopen-the default setting reverts back to 3.  I have also tried IMAGEFRAME and using a solid hatch pattern (color 255) as an alternate.  I get black squares when making a PDF.  Any ideas how to permanently turn off frames from printing?  I'm developing standards so this isn't something that I want all who use these details to have to do every time the details need printed.
Thanks in advance.
john.vellek
HI @Anonymous,
Is it possible to attach your file that refuses to retain your WipeOut frame setting in AutoCAD 2017? I would like to see if it behaves the same on my 2017. Please also tell me if you have fully updated your AutoCAD 2017.
[EDIT] When you mention color 255, do you mean 255,255,255 which is a true color for white?
John Vellek
imadHabash
>> When I close the drawing and reopen-the default setting reverts back to 3. <<
usually this behavior noticed when there is a lisp routine or plug-ins installed to your system. you may need to look around if it's match your case.
Imad Habash
I believe ACAD 2017 is fully updated. This is happening with multiple files and I have attached one for your reference.  You are correct with 255, 255, 255 -the true color for white.
john.vellek
Hi @Anonymous,
Your file is performing normally for me although when I run Audit it does find 21 errors. I, like Imad, suspect that you have something in your startup routines that is resetting the value.
John Vellek
How do I go about resolving this issue?  Is there an alternate command or procedure which will provide the same effect?  I do not have access to the administrative properties of AutoCAD as we have an AutoCAD specialist that loads this program and keeps it updated.
john.vellek
Hi @Anonymous,
You could perhaps create a macro or menu button that sets the variable every time you open the file. However, I suggest that you discuss this with your Specialist and ask why it is getting set to this value. Perhaps you can get it removed or adjusted.
John Vellek
