I'm not sure if this is the best forum to post this question in, so my apologies if not. I have also asked this question in elsewhere and have not been able to resolve the issue. Essentially, I want to use AutoCAD 2023 as my default DWG program, but Windows 11 will not acknowledge it because I had previously installed and then uninstalled AutoCAD 2024. I can open 2023, and it works fine, but I can't set it as the default. I have tried to reinstall 2023, and remove temporary files to no avail. If I manually search for 2023 to use as the default, Windows refuses to acknowledge it. Has anyone else had this problem?
