Window selection behavior issue
This morning when I use window selection I'm getting no difference between a crossing window or non crossing window. Picking from left to right, whatever objects are touched by the window are selected. Tried cycling the selection behavior but the issue persists. What have I done and what is the variable to change it?
imadHabash
if you type " W " when asked for select objects , any changes ?
Command: e ERASE
Select objects: w
Imad Habash
Kent1Cooper
That would happen if you first typed [or something else fed in] "C" for Crossing, which will make even a left-to-right window behave that way.  If it happens without that, and not inside some custom routine that might be doing that, I don't have any bright ideas....
Kent Cooper, AIA
I guess I was too quick to post to the forums. Restarting fixed it.
