Why my dimensions are still not associative?
Hi all!
I am going crazy 😄
My dimassoc system variable is on 2.
In the options "new dimensions are associative" is checked.
Yet i have noticed my new dimensions are still not associated...
Here is a block. If you use the loopup action the upper dimension (wich I copied from an other drawing) is associative, mine not.
Dimreassociate command can't solve it.
What seems to be the problem?
Thanks in advance!
I am using AutoCAD Map 3D 2021
Seems like i just had to reinitiate Acad... sorry
j.palmeL29YX
In the plain AutoCAD I can do >>this<<
If this doesn't work for you - I know, Map3D has often its own "rules" ( in my experience). I'd suggest to ask in the appropriate forum.
Jürgen Palme
