Why is there a white box in the middle of the screen after opening my cad, and then cad is stuck
rismawan_jaya
rismawan_jaya
Community Visitor
Community Visitor
pendean
Community Legend
Community Legend
@rismawan_jaya Have you installed the 2022.1.3 Update yet? Go get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
You can restart AutoCAD in safemode if needed after that, see the highlighted section here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-launch-an-A...
Once back in the program: Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD2022.
TheCADnoob
It looks like you are not logged in and that may be part of the problem as well.
 if you have access on your computer, try logging in there first
https://www.autodesk.co.uk/products/autodesk-access/overview#!
CADnoob
Valentin_CAD
@rismawan_jaya ,
This seems to be the LGS (Let's Get Started) window when launching AutoCAD after first install.
Take a look at these suggestions:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
