AutoCAD Forum
why is there a lock symbol on the x co ordinate when I use Copybase ?
1 REPLY 1
856 Views, 1 Reply
When i try to copy base 0,0,0 when i put in 0 for x co ordinate it turns red with a lock symbol.  What caused this and how do I remove it ?
Tags (1)
1 REPLY 1
Alfred.NESWADBA
you have first entered 0 for the X coordinate, so you have defined X and this is locked, then you entered the Y coordinate, so this is locked too, ... and the system is waiting to specify the Z value.
That's all normal for dynamic input, that's how it's working. E.g. if you draw a line with an angle you can "fix" the angle to 45° and move the mouse to specify the length of the line.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
AutoCAD Inside the Factory
