Why I Cant Find Layout Tool Tab ?
akmalrafiq2
Message 1 of 8
akmalrafiq2
Only Layout Tab appears there. I want to put Scale Bar
Replies (7)
Message 2 of 8
imadHabash
As much as i understand .. you can get your needed tool from   Tools >> Toolbars >> AutoCAD .  If that is not your issue , please describe more and clarify your need ?
Imad Habash
Message 3 of 8
akmalrafiq2
I just want to put Scale Bar. I watched the tutorial from this video https://www.youtube.com/watch?v=uuDdx3XTqmo&ab_channel=CADIntentionsw%2FBrandon but I cant find the 'Layout Tools' tab.
Message 4 of 8
akmalrafiq2
Message 5 of 8
imadHabash
This Layout tab is NOT exist in AutoCAD .. I'm afraid that it's an outsource plugin .
Imad Habash
Message 6 of 8
akmalrafiq2
Ah i see, thank you
Message 7 of 8
eshd0001
That can't be true. Autodesk refers to the same Layout Tools tab. I can't find it either. https://knowledge.autodesk.com/support/autocad-map-3d/learn-explore/caas/CloudHelp/cloudhelp/2022/EN...
Message 8 of 8
TomBeauford
It's part of Map 3D, the original post show only AutoCAD is loaded.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
