Why i can't join this polylines?
boy_alexutzu
boy_alexutzu
Hy guys!
I am new in Autocad and if you can help me i will be very grateful.
I work in electrical domain, production of distribution panels and i just want to join that mounting plate that i downloaded from the manufacturer site as dwg file.
The reason i want to join that mounting plate is to be able to hatch into real color of the mounting plate, to be more accurate.
If there is another way to color that plate, please tell me.
Until now i just created a block with this dwg but i didn't were able to color it.
I attached the dwg from the manufacturer site.
PS: i tried to set elevation to 0, then explode, then flatten, then join but nothing changed.
imadHabash
you can use BPOLY or BOUNDARY command to get a closed polyline shape . also you can use Hatch command ( Pick point ) to hatch your plate . click on below image
Imad Habash
vinodkl
There are multiple overlapping lines in the drawing you need to delete them first and then join them. To delete overlapping objects type in the command "OVERKILL" and then select the objects in the drawing and then click on "ok". Now all the overlapping objects will be deleted. After this use the command "JOIN" to join the lines into one🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
boy_alexutzu
Thank you very much for your help guys!
