Why does the top left menu button shut down autodad?
mjohnson3MF66
Message 1 of 27
mjohnson3MF66
Can the people who thought it was a good idea for autocad to close while clicking the main menu button, please explain?
There is already a beautiful very standard "X" in the top right of the program, with this well known function. So, even the option to close at the bottom of the application menu is not necessary.
So, why when I accidently click what is clearly a "menu" button more than once, without clicking anything that remotely says "exit" or "close" anything, does this kill the program?
It's been this way over many versions, so I assume there may be a reason for it? Or can you finally get rid of it?
Is there a way to disable this, or no?
I know my autocad crashes enough, that I really don't need it to close on me anymore than it already does.
Replies (26)
Message 2 of 27
Valentin_CAD
@mjohnson3MF66 ,
All users in this forum feel your frustration.
Hopefully this link may provide you a solution:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 3 of 27
cadffm
>>"please explain?"
>>"so I assume there may be a reason for it? "
That's the standard for well programmed Windows Programs!
Not special for AutoCAD 😉
Sebastian
Message 4 of 27
mjohnson3MF66
This must be the only so called "well programmed" application in the world then.
Menu buttons are not "EXIT" buttons. And a button that does something that it is not labeled to do is clearly the opposite of "well programmed."
A well programmed application is when, you click a menu button, the dropdown opens, you click it again, the dropdown closes,...without closing the entire program.
Message 5 of 27
mjohnson3MF66
It's not crashing. It's a regular shutdown just like hitting the "X" in the top right. If you've zoomed or made any changes to a drawing you can catch it by hitting the cancel button.
But, if your program has finally just opened when you do this, it closes with out the cancel button.
But, it is definitely not a crash. Just the way it is programmed to function.
Message 6 of 27
pendean
Community Legend
Community Legend
@mjohnson3MF66 Your post and the follow up seem confusing, or confused: how about you show us screenshots just in case no one is following correctly.
Or are you just new to Windows OS and wish to start/continue this old discussion here instead of at Microsoft https://answers.microsoft.com/en-us/windows/forum/all/how-do-i-disable-the-double-clicking-the-top-l...
Let us know what made today special for you and this OS feature.
And why is your AutoCAD crashing all the time?
Message 7 of 27
cadffm
Windows and Office  standard programs, Adobe and more.. just some samples for you to show it isn't a special AutoDESK feature.
It isn't the Button, but the upper left corner of program windows.
Open a program, double-click the upper left corner.
Sebastian
Message 8 of 27
mjohnson3MF66
I don't understand what could possibly be confusing. Just click the big red "A" in the top left of the program to open the application menu, then click it again to close it.
Message 9 of 27
Valentin_CAD
@mjohnson3MF66 ,
I agree with @cadffm, double clicking the upper left corner is a Windows feature to close certain programs.
Unfortunately, there is no control to switch off this behavior.
Consider your suggestion to Autodesk Support >>HERE<<.
Emilio Valentin
Message 10 of 27
pendean
Community Legend
Community Legend
@mjohnson3MF66 Consider not beating a dead horse and half-reading response to your posts: Start here https://answers.microsoft.com/en-us/windows/forum/all/how-do-i-disable-the-double-clicking-the-top-l...
and take up your discussion to continue your desired changes to Win 7/8/10/11 over at Microsoft's forums.
Good luck.
Message 11 of 27
mjohnson3MF66
Really? Half reading? Maybe the other commenters can claim this, but you seem to have failed to understand what was clearly written as if you didn't read much yourself. So, read it fully before you think you should tell someone else the same please.
Message 12 of 27
cadffm
>>"A well programmed application is when, you click a menu button, the dropdown opens, you click it again, the dropdown closes,...without closing the entire program."
And exactly this is how it works in AutoCAD too (and other programs with e menu there),
but if you run a double-click (instead of two clicks), you starting the MICROSOFT WINDOWS function to close the application.
Note: I also thinking: Adesk should have left the space
then it would only happen to the users which
1. Failing to hit the button
and
2. Double-click instead of clicking
Sebastian
Message 13 of 27
RobDraw
I bet you wish you could change your OP.
Rob
Message 14 of 27
pendean
Community Legend
Community Legend
Message 15 of 27
pendean
Community Legend
Community Legend
@mjohnson3MF66 I'll take you approving the response to your uninformed question as all the proof I need 🙂
Message 16 of 27
mjohnson3MF66
You should rather take my response as, if you start an answer by questioning a clear question as if you don't understand it, either YOU didn't read the full question, OR you're just trying to smart off.
A good reason for ignoring anything you wrote after that sentence, and moving on to somebody who matters.😉
Message 17 of 27
RobDraw
Or maybe, just maybe, the reality is it was a poorly worded question.
Rob
Message 18 of 27
mjohnson3MF66
Or maybe the other people who understood it just fine, would clearly indicate otherwise.😉
Message 19 of 27
RobDraw
I couldn't replicate the "issue" from the description. It sounds like you were talking about two separate clicks, not a double click.
This is not an AutCAD function as you have learned.
Plus, complaining doesn't belong in this forum, a user help forum. Product feedback is elsewhere.
Rob
Message 20 of 27
mjohnson3MF66
There has already been accepted solutions.
