Is there a way to have AutoPublish not add "-Model" onto the end of the file name whenever it creates a PDF file? This is highly annoying. I want the PDF filename to be exactly the same as the DWG file name. No extras.
Solved by pendean. Go to Solution.
Using sheet set manager is an option that will resolve this issue.
What are you publishing? Is it multiple dwg's "model" views individually? If you publish or plot a layout or model view into individual files it will append the layout tab name to your pdf file.
I am just in one drawing at any given time. When I set save, it triggers AutoPublish, AutoPublish outputs: Filename-Model.pdf
I have no idea what sheet set manager is. Interestingly when I go into a drawing, there is nothing there that I can find.
I do not believe that you cannot change it. Needing an extra script or program to do that shows an obvious flaw in the design of the software then. Should be able to just output correctly.
For me, I selected multi-sheet file, even though I only have a single sheet PDF, and when I ran "AutoPublish", it gave me the result I was looking for which was FileName.pdf . If I chose single-sheet file the output would have been FileName-Model.pdf or FileName-Layout.pdf
Could you please clarify in detail where to select "multi-sheet file"? I'm trying to plot "DWG to PDF" from Autocad LT 2023, same problem (annoying "Model" word), haven't found "multi-sheet" nowhere in setting.
Thank you!
@KYRYCHOK_IGOR wrote:...I'm trying to plot "DWG to PDF" from Autocad LT 2023, same problem (annoying "Model" word), haven't found "multi-sheet" nowhere in setting.
Not PLOT command.
You want to use PUBLISH command.
