AutoCAD Forum
why does autocad trim the opposite side
9 REPLIES 9
Message 1 of 10
ktnalive
439 Views, 9 Replies
ktnalive
I went into AutoCAD search, and their answer was to make the line not to be trimmed longer. What? These lines already cross each other.
1. The image I have presented features a circle that is intersected by a line that passes through it entirely. I require the lower section of the circle to be trimmed; however, only the upper section is permitted to be modified in ACAD. How do I fix this
9 REPLIES 9
Message 2 of 10
pendean
in reply to: ktnalive
pendean
Community Legend
Community Legend
Share that DWG file here please
Message 3 of 10
TomBeauford
TomBeauford
Post a drawing of the circle and three lines.
No other way anyone could answer just based on an image.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
2023
Message 4 of 10
paullimapa
paullimapa
Try repeating the Trim command on attached drawing which looks similar to yours.
Does it work now?
Paul Li
IT Specialist
@The Office
Does it work now?
Paul Li
IT Specialist
@The Office
Message 5 of 10
ktnalive
in reply to: paullimapa
ktnalive
Yes, so why didn't it work on my drawing??
Message 6 of 10
paullimapa
paullimapa
as other's have requested: share your dwg
Paul Li
IT Specialist
@The Office
Paul Li
IT Specialist
@The Office
Message 7 of 10
ktnalive
in reply to: pendean
ktnalive
This is getting stupid as it appears that this drawing trim problem only happens with this portion of the main drawing, as I redrew the portion elsewhere and everything worked.
Message 8 of 10
paullimapa
paullimapa
your current view is displayed in 3d:
Use VSCURRENT command and set to 2dWireframe and you can trim no problem:
Paul Li
IT Specialist
@The Office
Paul Li
IT Specialist
@The Office
Message 9 of 10
ktnalive
ktnalive
ROTLF that is too funny, not even YouTube knew this answer!
Message 10 of 10
paullimapa
paullimapa
that's because youtube's been around only since about 2005...while others of us here have used AutoCAD since the 80s...experience always trumps
Paul Li
IT Specialist
@The Office
Paul Li
IT Specialist
@The Office
AutoCAD Inside the Factory
