Why does AutoCAD crash at least 3 or 4 times a day?
mannes.karsten9GWCM
mannes.karsten9GWCM
It's honestly an embarrassment. Even if I were to start with a completely blank template and all standard settings.. this software will still crash if I have multiple tabs open and switch between tabs. Even double clicking on lines, notes, viewports, etc. will make this software crash. It's pathetic.
How is it possible I can handle multiple gigabytes of scan data in 3D cad software like Siemens NX without crashing but AutoCAD will crash over the smallest little things. Without exaggerating this software will crash at least 3 times a day even if I have all standard settings and a few lines drawn.
The amount of work I've had to re-do on AutoCAD simply because it just crashes whenever is unbelievable.
I'm currently working on this laptop:
i9-13950HX 2.2GHz (13th gen)
64GB RAM
Win11 x64
Nvidia RTX 3500
Everything is up-to-date. AutoCAD version is 2025.
And it's not just this laptop that has issues. Even previous laptops and desktop workstations.. it does not matter. Always the same crash report after switching tabs or double clicking an item. "Do you want to send the report"?
paullimapa
Perhaps the problem has to do with AutoCAD 2025 and your Windows OS?
Have you tried downloading and installing 2024 to test and see if the same problem occurs?
Paul Li
IT Specialist
@The Office
GilesPhillips
13th gen i9 processors are reported to have thermal issues, I've got one in my HP laptop and it regularly hits 100deg package and core temps (the limit for that package) performing pretty mundane tasks (and yes, I get a lot of crashes too).
Ensure you have Autocad running on the dedicated graphic chip, not the integrated one.  Clear out your %temp% folder - all the basic housekeeping really.
Raise the issue with Autodesk support, it's their product after all. you will have to dedicate some time to this yourself, don't expect a magic wand, overnight fix, but they are better people to be asking.
ACad, MEP, Revit, 3DS Max
CGBenner
@mannes.karsten9GWCM
Hello.  May I ask if you have sent any of these reports in?  They do get looked at and they often have vital clues to what the problem is.  I'm not a support person, and I used to be a customer.  I had many problems resolved from sending in Crash Reports, so it may be worth it to try, along with raising a Support case.  Good luck!
"Always the same crash report after switching tabs or double clicking an item. "Do you want to send the report"?"
Chris Benner
VincentSheehan
Is AutoCAD installed from a deployment image? Is the OS OEM to the laptops and workstations? Maybe check for memory issues.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Simon_Weel
Any error messages you can share?
CGBenner
Hello, do you still need help with this question?
Chris Benner
