White Blanked Status Bar
ST10111080
Observer Observer
ST10111080
Observer
Observer
Howdy CAD Community,
I am having trouble accessing the status bar on AutoCAD 2024, as there is a white screen over the whole status bar.
Could anyone please help with some insight into how I can get this blanked bar away from the status bar and the functions? Alternatively, if you can suggest ways of working around it?
I am having trouble accessing the ribbon or status bar on the control panel below on the CAD drawing space, which helps manage the drawing's layout pages, scale, object snap, line ortho, etc. is unreachable...
Thank you
Brock_Olly
That's your command line! It should not be placed over your layouts.
You can temporarily hide it with CTRL-9 or commandlinehide
See here for info about the commandline:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Command-line-is-mi...
imadHabash
Try to click the button "Maximize" ... upper/right beside the X button, to be "Restore Down". any changes?
Imad Habash
Valentin_CAD
@ST10111080 ,
Agree with @Brock_Olly .
Click the link and follow the suggestion:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
ST10111080
Observer
Observer
Happy Days!
I'm not stuck anymore, your advice worked like a charm.
Thank you very much @Brock_Olly
