Which version of Autocad is better on my old laptob?
Message 1 of 11
I have an old laptop with celeron proccessor, 256MB VGA ,3GB RAM and windows 7 Ultimate 32Bit.
Which version of Autocad is better on this device Autocad 2012,Autocad 2015 or any other version??
Replies (10)
Message 2 of 11
Alfred.NESWADBA
the major problem might be your graphic card with 256MB.
3GB memory and Windws 7 32bit is nothing bad, you can drive the current version (2016) of AutoCAD with that.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 11
It will also depend on what type of drawings you plan on making, 2D or 3D, You should verify your intentions.
Message 4 of 11
wispoxy
2D should be OK with 2012 and 2015. For 3D, stay with 2012 though you may still have lag issues.
Message 5 of 11
pendean
Community Legend
Community Legend
You can't buy 2012 or 2015 anymore: so try 2016 and see what happens.
Message 6 of 11
I use Autocad for Architecture plans or 2D draws
Message 7 of 11
I already have Autocad 2012& 2015 for my other laptop 🙂
Message 8 of 11
go to autodesks web site, select the software you are interested in running and see what they suggest for the minimum requirements of that software.
Message 9 of 11
pendean
Community Legend
Community Legend
Then there is nothing stopping you from answering your own question: you already have two computers/laptop to test side by side with your own files. There was no real need for you to post a question 🙂
Message 10 of 11
braudpat
Hello
1) With your OLD laptop, I will stay with version 2012 !
2) Maybe I will switch to version 2014 but NOT MORE !!
Regards, Patrice (I am not an Autodesk Advisor)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 11 of 11
JamesMaeding
Not to be completely evil, but you should consider Bricscad Pro as its less resource hungry.
Its $600 for a full seat, not $5000 like acad.
It will not make use of autodesk "object enablers" for things like civil3d objects, so careful if you sling civil3d stuff around.
It will still show, just in proxy object state which may vary a bit from full object enabler.
My advice on dealing with civil3d drawings is explode the aec objects which the civil batch converter does.
But you have to buy civil3d to get the bartch converter!
See, you think I'm taking business away from adesk, but you actually need their expensive tool to clean out their undesirable custom objects.
I guarantee that was not planned by them, call it dumb luck.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
