Which Command in AutoCAD combines 3d and 2d object with each other
Which Command in AutoCAD combines a 2d and 3d object .
imadHabash
you can use IMPRINT command . >> Click <<   would you please describe more your issue ?
Imad Habash
ChicagoLooper
You can combine 2D & 2D and combine 3D & 3D, but you can't join 2D & 3D together. What kind of 2D object? How many 2D objects? One or more?
Try taking your 2D polygon and extruding it a minimal amount, say 0.0001, so it becomes 3D. Then you can use UNION command to join the thin polygon with any other 3D object.
Chicagolooper
No real way to combine 2d and 3d objects other than what was mentioned. if you are looking to keep objects together as on you might be referring to creating a block with the BLOCK command, or as a temporary method GROUP.
j.palmeL29YX
What do you mean with "combine 2D and 3D object(s) with each other"? Show us an (or some ) example(s) please what you have and what you want to get.
Jürgen Palme
BeKirra
@Anonymous
"Which Command in AutoCAD combines a 2d and 3d object .
Does @imadHabash reply help?
I don't know what kind of "combination" you are looking for but command group might give you another idea.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
