Can anyone explain this to me?
I'm running ACAD 2018 (electrical). I have a Ricoh MPC3003 printer on a network. ACAD sees this printer through the configuration file MPC3003ENG.pc3. The printer works fine with letter and 11x17 paper sizes except this:
-PLOT
Yes
MPC3003ENG
11x17
Inches
...should be a valid command sequence called from a script, but ACAD is rejecting the 11x17! It comes up in the list if I hit question mark to view the possible forms, and as default it accepts 11x17 if I use a blank line there for the script. I cannot use 11x17, or "11x17" or any other variation to specify this form directly from the script, or from a command-line based plot sequence. What gives?
