where does eTransmit sends drawings with custom linetypes ?
yairMSKTU
yairMSKTU
i eTransmit a drawing which contains custom linetype and put it on shared folders.  now others can see it correctly.
but where did it send the .LIN   which i created for this drawing ?
if i email it to others who does not share the folder with me,  will they be able to see it ?
pendean
Community Legend
Community Legend
Did you search the ZIP file that ETRANSMIT creates? I bet you found out that Linetypes inside a file are, well, inside the DWG file, the external LIN definition does not tag along.
Same with custom hatch PAT files.
HTH
andrea_ricciNMVSG
sadly etransmit doesn't collect shapes lines nor patterns…
TomBeauford
Any custom CTB, STB, font or *.shx shape files referenced in your drawing's text or linetypes needs to be added in ETRANSMIT. Keep in mind standard fonts depend on what version of Windows or Mac you're using and what version of Office you're using. It's common for someone you receives your ETRANSMIT to need additional files. No magic way for ETRANSMIT to know every file another user at a different company may need.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
