When will Autodesk fix the "problem with 'custom' profiles"?
My interface never stays put. It changes on its own. This is a long standing problem that has been identified as "a problem with custom profiles". My frustration is that Autodesk enables users to customize their profiles (set things the way the user wants them) but it refuses to provide any way to find "problems" they may have and fix them.
I spend far too much time resetting my interface to my preferences after opening a session because Autodesk always makes its preferred adjustments to my interface. Some windows will be as expected except for their height and even their order when docked and stacked.
- It has been proven that switching between SDI=1 and SDI=0 will result in the command line presentation changing to AutoCAD's default setting when a new session is opened. (If AutoCAD's default was its prior setting you won't notice this).
- The SSM will NEVER be open when new sessions are started, regardless of previous profile settings.
- The SSM window will change its height during a session w/o user action. It has been observed incrementally growing to about 85% of the stack and shrinking to about 20% of the stack during sessions (The Properties Window is the other in my stack. I prefer them to both be at about 50% of the space available.)
The 2019 'solution' is to reset these things and then navigate to the Profile.aws file and make it read only; however, that prevents ANYTHING being changed in the Profile.aws file. Things like recent files still need to be saved to it and can't be with this 'solution'.
Autodesk needs to fix the "problems with custom profiles" so users are not wasting time resetting their interface every time Autodesk decides to change it unilaterally.
Here is the reference to the 2019 solution:
https://blogs.rand.com/support/2019/09/command-line-will-not-stay-docked.html
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
8.6.52.0 AutoCAD Architecture 2024
