Can't Delete Text Style
pamela.frame9M7MG
pamela.frame9M7MG
Hi
I've been updating some of my standard templates and want to delete one of the text styles because it is saying it is still in use.  I can't find it anywhere. I've tried qtext and quick select to try and find it.
ВeekeeCZ
Possibly try the Purge...
pamela.frame9M7MG
That helped me out. Great thank you.
cadffm
and if you really can't find it (if you can't understand the Purge-information, as shown above),
you can merge the textstyle with another one, command STANDARD
or share the data (.dwg), say what style you are talking about.
A lot of people are kind and offering help.
Sebastian
pamela.frame9M7MG
That's great thanks I think I have fixed it.
jayhar
  1. If text is in active its cannot Purge.
  2. may be text are used in title blocks or any another inside blocks
  3. Try QSELECT
CTRL + All > Comment QSELECT  > in Object type select MText > Below Operator Select All > Ok .
you can see the text are selected then deleted it.
May be text are in some blocks
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
