AutoCAD Forum
When printing a schematic from AutoCAD 2024 on a Canon TM-300 plotter, the preview window does not appear
6 REPLIES 6
ttbis
373 Views, 6 Replies
When printing a schematic from AutoCAD 2024 on a Canon TM-300 plotter, the preview window does not appear (although it did before) and the diagram is immediately sent to print - because of this, a lot of extra paper is consumed, because something may be incorrectly configured and I cannot see it without a preview window. How can I fix this? Everything works in other applications (Adobe Acrobat, etc.). The drivers are recent.
6 REPLIES 6
pendean
in reply to: ttbis
How are you triggering the PREVIEW window, and from which pop-up or button?
And if you use PREVIEW command, does that work without sending it to the printer?
ttbis
in reply to: pendean
Can I send screenshots step by step? (I have a non-English version of the system)
ttbis
in reply to: ttbis
Choosing a printerChoosing a printer
Printer PropertiesPrinter Properties
Additional Printer PropertiesAdditional Printer Properties
I put a check mark on "Preview"I put a check mark on "Preview"
Put a check mark on "Preview"Put a check mark on "Preview"
pendean
in reply to: ttbis
@ttbis Thank you for those images: this is not AutoCAD's PREVIEW, you'll have to ask Canon for support
This is the PREVIEW that is in the program we all have and use
ttbis
in reply to: ttbis
"And if you use PREVIEW command, does that work without sending it to the printer?"
If you mean this,
then it works so that I can see the print status that I set, but I can't see, for example, what size paper is currently installed on the printer. I don't get feedback from the printer in this case
ttbis
I just thought that since it works in other programs, but does not work in AutoCAD, then the problem is with Autocad. I will contact Canon support then. Thanks!
AutoCAD Inside the Factory
