when i open dwg file it show far away form geolocation as set..
hi. i ma new on autocad. i am working with someone on basemapping. he send file in dwg format and when i open it it show far away from wxact geolocation. i dnt know why that because its working on his pc but showing issue with mine.. can you help please?
Replies (16)
imadHabash
you may need to check your online maps service . >> Click <<
Imad Habash
hi. actually its not like i add location manually. he worked on location and rest i have to do..
so i want when i open file it show me same location as he worked on. but it shows far away.
if i add manually i have to set it by moving rotating.. hope you get it
imadHabash
i mean that your map may loose the connection from online map service . since we don't have your CAD dwg file take a look here for Geographic commands and check if any can help . >> Click <<
Imad Habash
it not look like i am loosing connection. i have dwg file with rectangle. if you can see and tell how to fix i can share file..
imadHabash
Sure , attache here your CAD dwg file and put a sign in your dwg where it should be please ?
Imad Habash
here is file dwg with rectangle i have to work within.. and the location should be 33.408929,-111.787748..
kindly check if it show same location to you or not..
ChicagoLooper
This looks like an infrastructure drawing. Are you using Vanilla AutoCAD or Civil3D?
Chicagolooper
I am using autocad simple dntknow about vanilla autovad . . what you
suggest? Why i am facing this issue?
ChicagoLooper
You have two sets of green rectangles. First on 3rd Street and the second set far away in the desert. Delete the rectangles in the desert.
Chicagolooper
Done. But how it effect the coordinates?.
Is it problem of live map or what?
ChicagoLooper
It doesn't affect the coordinate system. All you're doing is deleting unwanted lines in the desert and keeping the lines on 3rd Street. Deleting those rectangles doesn't affect drawing coordinates.
Even though your cursor is rotated, your drawing is still using the World Coordinate System.
Why is your cursor rotated at a funny angle? I say funny because the cross hairs are not parallel to 3rd Street and not parallel to  the edges of the green rectangles.
Chicagolooper
I am struggling with that. When ever i open file it get rotated and miles
away. . you get what is issue?
Pointdump
Ahmed,
"When ever i open file it get rotated and miles
away. . you get what is issue?"
Your drawing is--how can I say this kindly?--FUBAR'ed from top to bottom. It is a Civil 3D drawing with huge problems.
1. The Transformation Tab has been turned on with incomprehensible settings and rotation.
2. UCS has been rotated.
3. Edit Location has been used. Always a very bad thing in Civil 3D.
4. Unselectable entities are scattered all over.
It took a bit of doing, but I fixed your drawing. Please find it attached.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
thanks dave. but my colleague share dwg files and i face issue every time same ( away from set geolocation and rotated ). so how i fix this issue so i don't face this issue next time. can you tell. i like to know which setting of my autocad need to set
Pointdump
Ahmed,
"...my colleague share dwg files and i face issue every time same (away from set geolocation and rotated). so how i fix this issue so i don't face this issue next time."
How I fixed the drawing involved W-Blocking out the linework and using the ALIGN Command to re-position in a new drawing. But the simple answer is to tell your colleague to stop molesting and crippling their drawings. If this person won't stop, you need to sit down with them when they are drawing and see what they're doing. Then you'll know what to un-do to fix the drawing.
You have my deepest sympathies.
Dave
Dave Stoll
Las Vegas, Nevada
Haha. Thanks for your kind words. Actually when he open the files he dont
face issue but i live other region i am facing this. So dnt know how to
tell him to fix or stop doing what he doing. Btw thanks.
