When I enter the command it works as something wrong.
Before reading, I am not familiar with English. So I used a lot of Google translation. Even if you are uncomfortable to read, please understand. 🙂
O/S :  64bit Windows 10 Home 1803 -> Updated to 1809 yesterday
AutoCAD : 2019 Korean 23.0.46.0 (Studend Lisence)
acad.pgp is default
in detail.
1. type some command (ex : DIM)
2. and press Enter button
3. command will works wrong (ex : D(DIMSTYLE))
similarly, if I command BO, it works as B.
command CO, it works as C
It does not mean that the CAD will run with errors from the beginning.
But for some reason I do not know, I get an error, and once it starts to happen, it keeps happening.
in video, DIM will work and then D, then DIM will work only D, BO acts as B from the beginning even if you have never input B separately.
Other commands, UCS and U, EXT and E, MI and M, SHA and S, PLAN and P, etc., show similar errors as well as BO and B in the video.
I am only a student about two weeks since I started CAD. But why is this error and it is inconvenient to use program. I hope you can help me.
Thank you.
ВeekeeCZ
Try to:
- dock the command line.
- go to InputSeachOptions and turn all off.
Thanks for the reply. I would like to test it now, but no errors in right now. I will test your solution in the event of an error later.
