Announcements
When creating fonts with SHP files and vector codes, is it possible to return to a specific point?
jamieq
jamieq
I've been using a bold SHX font for many, many years. But only recently I've noticed that, due to the fractional arcs used for the numbers (I almost entirely use numerals with this font) the end point after all the vectors/arcs isn't at the same plane as the start point. For example, if I type "5" several times in a row, each 5 will be "lower" than the one before it. By lower, I mean the bottom of the 5 itself will be below the insertion point of the text object (assuming a standard "left" justification). I've attached a screen snip.
Is there a way to specify a start point of a shape and then return to it, rather than just follow the pen along each vector/arc until it ends?
Kent1Cooper
Having constructed an entire .SHP/.SHX font once [a very long time ago now], I don't remember ever using any such possibility, but in the >Help for defining shapes<, look at what I think would do it -- the 005 and 006 codes to "push" the current location onto the "stack" and "pop" it back out.  I assume you have the .SHP code for that character [gotta be a lot of code], to figure out where to put a "push" and a "pop."
BUT, such densely-filled-with-lines fonts date from way back [your "many, many years" ago] before .TTF fonts could be used in AutoCAD, and that was the only way to fill weightier text in solid, requiring a pen weight at least as thick as the spacing between the infill parts, and therefore varying with the size, so it would end up solid.  Now that you can use .TTF fonts, it would be infinitely faster and simpler to switch to using one of those than to find a way to fix that .SHP font.  Your image looks quite similar to the shape of a 5 in ARIAL, which virtually everyone has, so you wouldn't need to send your .SHX font file to others who probably don't have it.  And you would not need to deal with the need for different plotted lineweights for different text sizes -- all would come out filled in solid regardless.
Kent Cooper, AIA
jamieq
Thank you! I never quite understood what those codes did, so I just forgot about them completely. But I just added a push and a pop to the shape definition of the number 5 and it worked perfectly!! Now I can fix all the other numbers that are broken, which is pretty much all of them. I would use a TTF but the AutoCAD extension I use requires a shape file to turn lower case letters to fractions.
pendean
Community Legend
Community Legend
May I ask why you're not just using a TTF font that is always filled, and can be BOLD or 'regular' anytime you want it to be? Curious the amount of effort you are putting into something that will not be very satisfying in the end if you are very picky about output quality IMHO.
jamieq
I use an AutoCAD extension called SprinkCAD which is used for fire
sprinkler design. SprinkCAD uses q for 1/4, h for 1/2, and t for 3/4. The
program wouldn’t work with a TTF font. There’s another sprinkler design
software called HydraCad that does the same thing, but with [, /, and ].
Both programs have a couple of different font options, and I’ve been using
the bold version for a decade. But I only noticed just recently that some
of the numerals were causing issues. Possibly after I finally got glasses
with the correct prescription. I use Arial for all my notes, etc. I only
use the shape file for sprinkler pipe dimensions as part of the design
software.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
