What variable is causing this display behavior?
Neilw_05
Mentor Mentor
Message 1 of 13
Neilw_05
Somehow I changed a setting in my drawing file that is causing line work to not display properly. In the attached screen capture I am showing how the line work is displayed in the problem drawing (left) and how it displays when I bring it into a new drawing (right).
I have checked: Line weight display toggle is off, Display plot style toggle off in page setup, 2d wireframe visual style is current (matches visual style in new dwg). No viewport overrides in effect (both views shown are model space tab). I recall changing something related to transparency before this happened because I was having issues with imagery in an XREF that was masking the line work. Unloading the XREFs makes no difference.
What else can it be?
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Replies (12)
Message 2 of 13
john.vellek
Hi @Neilw_05,
Are you displaying Plot Styles in your page setup?  That is my first guess. Can you attach your problem drawing?
John Vellek
Message 3 of 13
Neilw_05
Display Plot styles is off in page setup.
DWG is attached. Note the color overrides on the objects are not being displayed.
WIN 10 64 PRO
Message 4 of 13
Neilw_05
I just updated the CAD file in the last post by removing the Civil 3D pipes. Please update if you already downloaded.
WIN 10 64 PRO
Message 5 of 13
john.vellek
Hi Neil,
Can you run AUDIT, PURGE, -PURGE>Regapps on your file?
This is what I am seeing on my screen.
Should it look different than this?
Is this happening in core AUtoCAD or just in Civil 3D?
John Vellek
Message 6 of 13
Neilw_05
Audit and purge are clean. It must be machine specific. However when I paste into a new dwg on the same machine it displays properly. I'm baffled.
WIN 10 64 PRO
Message 7 of 13
john.vellek
Hi Neil, When I AUDIT your drawing,  it finds 12 errors in your last file and 71 regapps are removed.
Are you running in AutoCAD Civil 3D or core AutoCAD?
John Vellek
Message 8 of 13
Neilw_05
The only other thing I can think of is a toggle in the drawing environment.
WIN 10 64 PRO
Message 9 of 13
Neilw_05
I purged 71 regapps too. I didn't have any audit errors. I am running Civil 3D.
When I open in plain AutoCAD everything is fine. It is something in my C3D environment. I'll post to the C3D forum.
WIN 10 64 PRO
Message 10 of 13
BeKirra
Sorry I can't open your file as I am on 2016.
Here is my guess.
Is your drawing created from the template which is the same as "Drawing2" on right-hand side of the image?
And in your case the 1st thing I would do is comparing the layer properties (e.g. Color, Linetype, Lineweight, Transparency, etc.) between 2 drawings.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 11 of 13
Neilw_05
I am opening the same drawing in 2 apps, C3D and plain ACAD. Thus all drawing settings are identical.
WIN 10 64 PRO
Message 12 of 13
BeKirra
As I can see you are not a beginner.
This may be a silly question: Are "color" and "linetype" of the lines set to "bylayer"?
X² + Y² = C²
Message 13 of 13
Neilw_05
Problem solved in C3D forum.
WIN 10 64 PRO
