>>"Do you have AutoCAD LT or full AutoCAD?"
Doesn't matter (for standard installations)
>>"I can't find any mention of -dwgunits in the AutoCAD LT help"
Doesn't matter, or do you can find it in AutoCAD product documentation? No,
it's an undocumented command to handle AEC DWG setups, nothing for plain AutoCAD dwg drawings.
>>". It does work with full AutoCAD and with the AEC verticals."
and LT
I guess @cocopinkhot is in the wrong board and he uses AutoCAD FOR MAC
>>"The main benefit of -dwgunits is that it automatically offers to scale drawings relative to the INSUNITS type changes."
Right
>>"It does have some drawbacks wrt blocks in the drawing."
>>"The block definitions of blocks other than layout blocks aren't changed to reflect the new units types "
And this is good&correct, another result would be a nightmare
>>"and that can complicate things."
What, or Why?
With starting this undocumented command, you add an AEC DWG Setup into the file (if not already there), so from know
you have aec content inside and products will handle accordingly, including Autocad unusual behavior or problems.
But as always: You should know as much as possible about what you are doing, then everything will be fine.
