What hardware should be upgraded in order to run smoothly for a drawing of 970,000mm x 790,000mm?
I am using i7-11700 CPU, 32GB RAM, M2 SSD, and RTX 2060 for my computer. But it still runs slowly when I am working on just 1 drawing of the above dimension.
The CPU is running at 3-4% and ram is running at 17%, harddisk at 2% and the GPU at 1%. It seems that the computer is not running at its full capacity.
I know that block and layer have great influence when i review and amend the drawing. But i can not delete or amend them as they are set up by other parties. So how can i upgrade my computer? Have a ram with lower CL valve? Or any other suggestion?
