What happened to reference dimensions??
S7RM7RPR
S7RM7RPR
I'm using AutoCAD 2018 and I feel like an idiot but I cannot for the life of me figure out what happened to reference dimensions. The only AutoDesk mention of it is in "power dimensions" which I also can't find and this has me very confused.
Question 1: what the heck happened to reference dimensions??
Question 2: if it's not in AutoCAD anymore, what am I supposed to use instead of reference dimensions?? I thought they were a common thing.
jeff.lentz
Inventor has them as a dimension type. I don't recall them in AutoCAD, but you can always click into the dimension and put () around it, if that's what you're referring to. You may be able to set up a dimension style that does this for you, but I'm not a styles expert (by choice).
S7RM7RPR
Yea I thought of that too, the only trick is if you're using dual units (as I am in this case) you can't bracket the whole dimension like in Inventor. I regularly use it in Inventor too so that's why I'm so confused about why I can't find it
imadHabash
I'm afraid that you're talking about AutoCAD mechanical feature !!
Imad Habash
S7RM7RPR
*insert temper tantrum here*
RobDraw
There's no crying in CAD.
Rob
GrantsPirate
In dimstyle set the prefix for the primary units with a ( , then in the alternate units set the suffix ) .
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
