Web feature for the AutoDesk Docs: Layouts import to SSM issues
nschaferKKGPZ
Observer Observer
nschaferKKGPZ
Observer
Observer
I have been Pidgeon holed into using 2023 at work when previously working off 2020. 2023 has a Sheet Set Manager for Web feature for the AutoDesk Docs function for Sheet Sets and now if I create a new layout or copy a layout I cant Import that to the Sheet Set. It shows greyed out. Is this function going to be added or am I missing something. When I download the files onto my local server it works like the previous version but this is time consuming as files can run large. Is there another way around this or am I doomed to Download files every time?
[ The subject line of this post has been edited for clarity by @pendean Original: Why can't I import layouts as sheets]
RobDraw
You make it sound like a bad thing.
Rob
pendean
Community Legend
Community Legend
@nschaferKKGPZ Nothing changed between 2023 and 2020 when it comes to layouts and sheets. Nothing. Looks like you adopted all new features instead.
You need help with AutoCADDOCS and web-base SSM, is that correct?
JTBWorld
It is limited in functionality. Not sure about your specific issue though.
https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-45700EEC-B549-4879-9C8C-7C23AB54B112
https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-AF282E42-92DC-4780-9F48-A208910C6C97
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
