05:14 AM
Hi
I have got a drawing that has got about 500 blocks in it and i need to wblock them out one by one
They have all got text above them that gives the name that i want to use for the block name then i just need to select the objects and the insersion point of the block
I have found a lisp on the fourms that seems to work for other people but it doesnt seem to work for me it asks me to select the block name text i select it and then it doesnt do anything else
(defun c:qwblock (/ DIR ENTXT SS TXT PT TXT0)
(setq Dir (getvar "DWGPREFIX"))
(vl-cmdf "_undo" "be")
(while (AND (vl-file-directory-p Dir)
(setq enTxt (car(entsel "\nSelect Block name Text: ")))
(eq (cdr (assoc 0 (entget enTxt))) "TEXT")
(setq txt0 (cdr (assoc 1 (entget enTxt))))
(not (findfile (setq txt (strcat Dir txt0))))
(setq pt (getpoint "\nPick Insertion Point: "))
(setq ss (ssget))
(progn
(vl-cmdf "_undo" "mark")
(vl-cmdf "_move" ss "" pt "0,0,0")
(vl-cmdf "_zoom" "object" "p" "")
(vl-cmdf "_-wblock" txt "" pt ss "")
(vl-cmdf "_undo" "back")
(vl-cmdf "_undo" "end")
(princ)
)Would anyone be able to help me to get this to work ?
Tia
