Wblock Lisp
Wblock Lisp
Wblock Lisp
Hi
I have got a drawing that has got about 500 blocks in it and i need to wblock them out one by one
They have all got text above them that gives the name that i want to use for the block name then i just need to select the objects and the insersion point of the block
I have found a lisp on the fourms that seems to work for other people but it doesnt seem to work for me it asks me to select the block name text i select it and then it doesnt do anything else
(defun c:qwblock (/ DIR ENTXT SS TXT PT TXT0)
  (setq Dir (getvar "DWGPREFIX"))
  (vl-cmdf "_undo" "be")
  (while (AND (vl-file-directory-p Dir)
       (setq enTxt (car(entsel "\nSelect Block name Text: ")))
       (eq (cdr (assoc 0 (entget enTxt))) "TEXT")
       (setq txt0 (cdr (assoc 1 (entget enTxt))))
       (not (findfile (setq txt (strcat Dir txt0))))
       (setq pt (getpoint "\nPick Insertion Point: "))
       (setq ss (ssget))
    (progn
      (vl-cmdf "_undo" "mark")
      (vl-cmdf "_move" ss "" pt "0,0,0")
      (vl-cmdf "_zoom" "object" "p" "")
      (vl-cmdf "_-wblock" txt "" pt ss "")
      (vl-cmdf "_undo" "back")
  (vl-cmdf "_undo" "end")
  (princ)
Would anyone be able to help me to get this to work ?
Tia
regisrohde
Works, save the block in the same folder dwg.
Please mark this as the solution if it resolves your issue.Kudos gladly accepted.
Regis Rohde
doesnt seem to be working for me for some reason
i run the command qwblock
click on the text that i want to use for the block name and it doesnt do anything
heres whats in the command window
Command: QWBLOCK
Command:
If i remove some of the lisp it lets me select the text and then objects and insersion point but it wont output the block because its not passing all the information to be able to save it
here is what i removed and it allows me to do the above
It seems to be working for me now i have removed
Kent1Cooper
Were you perhaps selecting an Mtext object, instead of Text?  That would stop the whole thing, because the (and) function would return nil.
If that's the issue, but you want to allow either Text or Mtext, you could replace the above with:
(wcmatch (cdr (assoc 0 (entget enTxt))) "*TEXT")
which would allow either, but it would just quietly stop if you picked, say, a Line, rather than giving you some kind of error from trying to get text content from such a thing, or look for a file name that's only a directory name because no text content is added to the end of it.
Kent Cooper, AIA
