Wants to make Boundaries automatically.
These are single lines and i wants to convert these as boxes where the lines were intersected. Please help me out with any Lisp file or someother solution.
Thank you.
imadHabash
Hi and welcome to Autodesk community,
you can do it by using ARRAY command line after drawing a rectangle.this command for a such need.
Good Luck...
Imad Habash
Thanks to your Reply.
 which i have provided the diagram as a Sample. i need to make a bunch of boundaries with uneven sizes, so array is not the solution as per me. please provide me alternate solution or Lisp file to proceed.
M_Hensley
The manual way to do it is with BOUNDARY command using pick points option and then pick inside each area.
Kent1Cooper
This same question came up just last month.  Check out BoundaryMultSel.lsp with its BMS command, here.
Kent Cooper, AIA
