Want have all Xref file to have the same layers as the host file
maramuresul
maramuresul
I want to have the same layer for all xref as in the host file.
For example if I have a host file named abc.dwg and a layer of Lights , I want to have layer Lights to be also in the
Xref files not to have as I have now xyx|Lights.
Having a floor plan with a lot of rooms , each room being a Xref, it creates separate layers for each Xref.
I want to be able to switch off layer Lights in host file and to be switched off in all xref files.
Thanks.
qnologi
imadHabash
Not applicable . this is how AutoCAD xref layers treat since you want xrefs to still without bind .
Imad Habash
3wood
I guess you can set up a layer filter so you can quickly select all layers contain "lights" and turn them off.
Kent1Cooper
@qnologi wrote:
https://cadtips.cadalyst.com/layer-properties/rename-layers-bound-xrefs
Be aware that this can be applied only after the Xref has been bound into the current drawing.
Kent Cooper, AIA
