wall(2D) that automatically deletes the intersected lines
Message 1 of 9
How can i make Autodesk architect like feature :Wall cleanup in autocad .......ANY TIPS
Accepted solutions (3)
Replies (8)
Message 2 of 9
Patchy
Can't.
Plain Autocad is not Autodcad Architecture.
Message 3 of 9
john.vellek
Hi @Anonymous,
Ketiv Technologies (as well as others) used to have some simple lisp routines that would help clean up "wall" intersections.  Wall-L.lsp, Wall-X.lsp, Wall-T.lsp might be things to search for on the Internet.  I don't see anything that will do this in the Autodesk App Store but I bet there are some lisp routines hiding out on the Internet.
John Vellek
Message 4 of 9
gotphish001
I use FILLET with a zero radius to clean up walls for simple walls at least. See screencast. That or I just use trim and hold shift to make it extend, so I don't need to flip back and forth between those two commands.
Nick DiPietro
Cad Manager/Monkey
Message 5 of 9
pendean
Community Legend
Community Legend
Try MLINE objects in plain AutoCAD: way smarter than dumb lines used in any free lisp you find. Just be mindful they are NOT the same, but close enough.
Or find/Buy a third party Architectural add-on with intelligent walls/doors if subscribing to the actual software you need is not an option.
Message 6 of 9
Thank you very much sir......half of my problem is solved but what can i do for x or t intersections.....Any idea...
Message 7 of 9
Thank you sir for your help.... really appreciated it........but these lisp doesnt work for mline only on drawn and offseted lines......Anyway thank you SIR for helping me out.
Message 8 of 9
I used Mline and mledit....it is long process so i wanted something fast.....Anyway Thank you sir!
Message 9 of 9
I found the solution thank you
