Hi all
I have a drawing with a lot of OLEs from XREFs which overlap heavily in model space. I have VP frozen the OLE layers from the layouts so that I get a clean view of the info I want. In the layout tab, the layout looks fine but when plotted all the vpfrozen OLEs are still visible in the viewport.
I have attached files which simplify the problem as much as possible. "xref ole.dwg" has an OLE on it's own layer, "drawing with xref.dwg" xref's "xref ole.dwg" and has a layout that only has 1 viewport, with the OLE layer VPfrozen. But it still plots the OLE when PDF'd as shown in
drawing with "xref-Layout1.pdf"
Any ideas?
